Elec noise issue in speaker
I'm far more familiar with other aspects of the car than the rats nest of interior wiring harnesses, etc. Can anyone point me in the right direction to resolve this noise coming from the speakers?
It speeds up as the engine does, OEM audio system was fine until today.
Hi Vancouver
Under the Bonnet/Hood there is an 'Anti Crackle Box' that suppresses electrical noise from the Alternator (or something like that)
Have a look on Page: 40 of my 'Cherry Blossom' Restoration Thread and you will see a Photo of the suppressor box 'thingy' that I am talking about
It could be something to do with the Noise you are hearing, maybe a wire has come off it or something?
I'm not an electrical expert so I have no idea and didn't even know what that Box was for although it could be worthwhile Checking out, in case its that
Here is the Link: Anti Crackle Box Suppressor might be affecting your Stereo? (See Photo of where to find it)
Mkii250 (04-24-2020)
A bad ignition condenser can have several effects on your car.
1. Heavy Static in the Radio
If the condenser is not able to hold a charge, there will be significant sparking inside the ignition system. The electric charge and the magnetic interference that it creates will cause a significant amount of static in your radio. Stations that you can normally here clearly will now be very difficult to make out and will cut in and out sharply. Since the sparking only happens when the engine is turned on, the radio will work normally when the engine is off and only the battery is functioning. Once the car starts again, the static will resume.Does it happen when the engine is not running?
The group where the orange wire is. Should be 8 wires (4 speakers). Other group is your power/ground/accessory on/antenna (or power on..used for power ants or to turn on an amp) and constant i think.
VancouverXJ6 (04-29-2020)
My trip computer could use a 'reflow' as well. Similar sporadic issues
*disclaimer do not bake electronics the fumes are toxic.
Hi Vancouver
When I came to fit a new Stereo in both of my Cars which I had never ever done before they came with a very useful Wiring diagram which made the job dead easy and since many of these Stereos seem to be all wired up the same, if you have a look at the diagram in this Thread of mine
You should easily be able to identify the Colours of what Speaker Wires go where
How to Fit an Aftermarket Stereo in an XJS V12 including Step by Step Photos
Hi Vancouver
