Electric radiator fan
My 1996 4.0 overheats a bit in traffic on hot days, hot enough to turn the electric fan on. It was running and I cut the engine off and with the bonnet raised was surprised to find that no air was coming through the radiator. All the air was blasting upward from between the fan shroud and the ac condenser.
I pulled the flexible rubber sheets away from the back of the radiator and still got no airflow. It seems as if the ac condenser or the radiator is clogged up with dirt although I can't see any.
Have any of you experienced this?
RagJag
RagJag
Received 10,979 Likes
RagJag (08-06-2015)
