Electric water pump
#61
If it is true that oil temps can get to 300 F on a bypass cooling car, this could well cause all sorts of problems, as even synthetics start to degrade well before that. As far as I can see, the one thing we all lack is actual in-use oil temp figures. I have in stock and ready to fit (not easy as it requires the subframe to be dropped to fit the engine to cooler-flexibles steel pipes) a full flow oil cooling system to replace my OEM bypass oil cooling system. I have also managed to acquire a sump plug with a 1/8 npt central tapping for an oil temp gauge sender. This gauge I shall run off the cigar socket as a temporary item as I do not want to ruin my dashboard or the OEM interior.
Before doing the full flow conversion, once summer arrives, I shall take sump oil temp readings during a long fast run on a hot day, including a couple of heat soak stops etc. If the figures are OK (ie below 100 C, 212 F) I shall not do the conversion! If they are higher, I shall, and will then repeat the test with the full flow cooling system and see what the difference is. If anyone has these figures already, please post then.
Greg
Greg
also i do agree that a full-flow oil cooling system just may be excellent for Mid east and very high temp conditions. Jags got a bad rap in those countries.
ever since Ford aquiered Jag they made design improvments that seemed to help things , like full circle rear crankshft seals, modified cooling systems, full cool oil systems, and cooler core designs.
and a myrad of electronic changes
after 20 odd yrs, Ford/ Jag engines have finely been brought up to modern day engineering practices.
i was shocked back in early 90s to find a rear seal made of rope,WTF, my 1978 Jag V12,,
GM and ford left that stuff in the 1950s
#62
I drive 4 miles to work... I sometime take the long way around to take more time and let the oil get to temp... short drives with out the oil coming up to temp it death for our nice v12s... it is the making of some nice sludgy oil
I would be happy w 240 to 260...
240 light load and 260 putting it to it...
ronbros (01-05-2016)
