Electrical help
Electrical help
Hi everyone, pulled the wiring out on my 6.0 v12 to refurbish some time ago and now suffering from brain fade. Can anyone fill me in on the "shorting plug" in the engine management harness. it is green/pink from ecu then becomes black/green after shorting plug. The problem is I can't recall what this plug is or what it looks like, can anyone help???
_______________
1994 XJS 6.0 Litre (added by GGG)
_______________
Hi John
You will be far more likely to get knowledgable eyeballs on your problem and some help if you post this in the relevant model forum.
Very few visit this area and none of them that I know off know much about the V12. If you post to the XJ6 area you may get some feedback from Grant Francis or Doug Dwyer who have lotso knowledge in that area.
johnlayla (07-13-2019)
The following 2 users liked this post by warrjon:
Greg in France (07-13-2019),
Received 10,979 Likes
Not sure about the later cars but earlier versions had a 'shorting plug' in the harness immediately adjacent to the ECU....with the same wire colors you've mentioned. Red connector, on a sub-harness that was a few inches long. This was for enabling/disabling O2 sensor feedback for testing.
Is this what you are referring to?
If not, the only thing I can think of is the Marelli stretegy link as mentioned by Warren. That's in the engine bay, typically in the neighborhood of the LH intake manifold, towards the rear....if I recall correctly
Hi John
scrappyloz
01-16-2011 08:23 AM
Scottyobmu
11-30-2009 05:29 PM
Flying Finn
07-20-2009 09:28 AM
ocjmakaveli
11-26-2007 06:37 PM
