Electrical Problem
Exercise the hazard switch a bit vigorously a couple dozen times.
The contacts inside the switch can oxidize and the exercising will sometimes clean them.
The turn indicator circuit takes its power from the hazard switch. A problem in the hazard switch can disable the indicators.
If no joy you could try just replacing the flasher. There's a decent chance that's the problem. Ideally some diagnoses with a test light or meter would come before replacing parts but, as guesses go, a flasher isn't very painful.
The following 2 users liked this post by Doug:
Grant Francis (03-15-2021),
ptjs1 (03-15-2021)
You have to remember you have Lucas electrical parts. They barely work when new, and only get worse with age. Nothing strange at all.
