electrical short circuit
If you had a short circuit it would blow the fuse and be easier to find. You have either got a circuit that is not shutting down or a circuit that is staying live due to a ground fault.
If you know you are drawing 4A then I'm assuming you have a meter.
If this were me I would put the car in the position where you have the draw, pick a fuse box and start pulling fuses until you find the culprit.
Alternatively, you can use a test light and trace the circuits that are live when they shouldn't be.
Either way it may take a while, but be methodical and you will find it.
Hope this helps,
Hope this helps,
The model forums are the place for tech questions and members here with the same model should be able to help.
Thanks guys I was hoping it would be easier than squeezing my fat butt down into the foot wells.
If I knew where the (right) and (left) main positive nodes were I could isolate down to the starter/Alt area or the main fuse panel areas. I have a gut feeling it's in the starter/alt area.
Thanks again
Thanks again
aholbro1
08-05-2021 05:02 AM
