electronic flasher
electronic flasher
This may have been covered before. I pulled the flasher under the dash (which worked) and put in an electronic flasher. Doesn't work. I added led's to the tail lights and couldn't figure out why it didn't work. Too fast with the OEM flasher.
Well... the OEM flasher is wired differently. The 'load' is on a different terminal. I pulled the wires out of the socket and re arranged them. Works perfectly. I bought one that is adjustable so now I can regulate the flash speed. ..Perfect.
JigJag (07-13-2019)
NTL1991
XJ40 ( XJ81 )
07-27-2013 03:19 PM
