Electronic Ignition
Electronic Ignition
I’m thinking of converting from existing points / coil to a solid state no points ignition system for my 86 XJ-S 3.6.
ive read about the advantages in general terms, however I have had no discussions re the sensibility of converting my 3.6.
appreciate the thoughts of you experts.
many thank.
Mike
86 XJ-S 3.6 manual
many thank.
Mike
86 XJ-S 3.6 manual
Received 10,871 Likes
Grant Francis (06-25-2020)
XJS from 1986 has vacuum operated distributor and Lucas 8CU engine management system which is obsolete crap connected with modern tech engine. It was replaced in mid 1987 by 9CU system with MAF sensor and vacuum-less distributor which only distributes spark. Unfortunately the 8CU is nothing but trouble. Was having similar idea some time ago, however there it plenty of fiddling involved. Custom fully adjustable engine management is your option. You will need crank and MAF sensors. There are digital, programmable distributors to retro-fit - not sure about AJ6 engine.
mike
