Electronic Ignition without Dizzy Spinner?
In theory, the entire V could be emptied out, incl. pedastal. BMW style throttle via an alteration in the position (turning them 90° so they face the front) and then using two cables on one pull. There dizzyless ignition system. Check the late 6.0l V12s from the XJ40 (XJ81) and X300 (X305). They had I think 2 coil packs with 6 connections.
I personally see no reason to remve the dizzy. It's not like these engines need distributorless ignition setups. You won't see much gain either. If it were a high performance engine, say like Warren's build, where everything is apart in the first place, then yeah. But otherwise I'd leave it as is.
ronbros (11-05-2017)
As the Lucas OPUS on the pre HEs is very prone to age-related failures, updating it for a RE-OPUS conversion is a good idea.
Greg
To go distributorless ignition you would need to change the ECU for either a programmable or the later Denso V12.
I agree moving the AC compressor is a good idea. The old GM A6 is a very large heavy unit and replacing it with modern Sanden or Denso relocated to the side has been done before.
