Eliminating air pump on V12?
Oh, jeeeezzzz....it was years ago! I think it was a ported source (as opposed to contant vacuum) on the underside of the throttle body.
Or maybe above the thottle body?
Easy enough to check: you want one that doesn't have vacuum at idle but DOES have vacuum just as the throttle is cracked open.
Received 10,876 Likes
On HE V12 with a Lucas CEI Distributor? No, it was a vacuum *advance* type system, not vacuum retard.
I believe some of the 70s vintage V12s with the Lucas/Opus ignition were a vacuum retard type system, though.
I decided to try something (new air pump was 700$?!?!?)...
I took the air pump off...opened it up and "poured the liquid wrench to it. Then I put a 24" pipe wrench on it...It actually came loose!!! lol
It isn't really functioning as an "air pump", but makes a great dummy pully!!!!
Just thought I'd share...in air conditioned comfort!!!
![Icon Woot](https://www.jaguarforums.com/forum/images/smilies/icon_woot.gif)
I know this is a rather old thread, but I have an 85 xjs and I'm pulling the motor soon and like the original poster I want to delete basically everything possible to give it a better look and remove any potential failure points. A/c compressor is junk so I will be removing that entire system as well.
So what all did you remove/plug? over run valves, air rails, air pump, a/c system, evaporator canisters? Any modifications to the crank case vent?
Awesome! Thanks guys!
I plan on keeping the A/C, but the airpump, rails and various hoses are going bye bye.
This should make working on it somewhat easier, not to mention without the exhaust tubes coming up the back it will be easier to get to the transmission bolts.
Anything else I can eliminate while I've got the engine out? EGR, vac hoses?
Thanks again!
Thanks again!
I know this is from an old post but do you still have this idler pulley kit?
#30
Sold; but a better alternative...mount a GM SI alternator in the air pumps location. Eliminates the Bosch ribbed belt which is fitted behind the other 3 belts.
Put in an electric fan kit and eliminate the crack prone engine/pulley driven fan and you have a sweet accessible setup. I have a spare GM SI if interested.
#31
#33
#34
XJ6Paul (05-15-2020)
#35
On-board monitoring of the air injection system began with the 1995 cars and the introduction of OBDII. I don't think the car has any way of 'knowing' if the pump is in place and working or not.
I'm with Greg. I don't think you'll have a problem
#36
I have removed it from my 94 V12 6.0 and it does indeed throw a fault code so the check engine light is on permanently. Just an FYI. I will probably put it back on.
#37
#38
#39
