EM brake pad replace
Greg
orangeblossom (05-23-2016)
I contacted SNG Barratt. They couldn't tell me anything definite about the Kevlar pads having better bonding. There answer was just that they were excellent pads made by reputable manufacturer and carried (I believe they said) a 1 year warranty. It's a bit disappointing since about the only thing preventing lifetime service is the bonding.
Excellent point, ask them. Having had real problems with mine at the car road test, I redid my (in UK speak) handbrake to make it far, far better, and I used footbrake pads with a modern system of backing, cut down to size, plus various other mods. In case you are interested, I attach the paper I wrote explaining it all.
Greg
Greg
Of course, the brake is still inop, but that is probably because the car has been driven with the brake engaged. I now have something to inspect - whether the pad has come free from it's backing. If all I need to do is replace the pads, I'm a happy man.
Thanks again for a useful post!
Greg in France (05-26-2016)
Received 10,871 Likes
Greg, not to "hijack" another members post, but I want to thank you for sharing your paper on hand brake improvement. I just bought a 96 XJS-C and thought the hand brake was inoperable - I could pull it and it felt like the cable was disconnected, since the lever moved freely up and down. Another member said he had the same issue, but realized a transport driver had really yanked the lever up to engage the brake. That gent tapped his "ratchet bolt?" and the brake released. I went to my car, gave a good pull on the lever while pressing in the release button and sure enough, the lever released.
It IS very useful advice from Greg.
However, you have a 1996 XJS, correct?
If so, you have a different parking brake system entirely. You have outboard calipers and parking brakes. Greg's article refers to 'inboard brake' cars.
Quite true Doug, but I GREATLY appreciate the thoughtful "thank you" from both you and Davemack. Thanks to you both
Greg
Regardless, it was nice of Greg to put that tutorial out there. I'm sure others will find it both useful AND applicable.
coxzilla97
12-11-2018 02:43 PM
