Engaging Compressor Clutch
Hello fellow XJS'ers,
Morris (89 XJS V12) needs freon. It's been empty for way over five years, and I'd like to see what, if any, leaks he has. So, as the compressor clutch won't engage due to no pressure, how do I engage the compressor clutch so the AC system can suck up some freon/oil/stop leak? Or do these cats have a system where you put some freon/oil/stop leak and the clutch will engage?
Eskr
Eskr
On most ac compressor clutches, if you jumper positive to the clutch terminal directly the clutch engages.
But, checking for leaks only involves adding some freon through the charge port and checking with a leak tester. The freon will normally migrate to both high and low sides. You do not need a full charge to do leak testing.
Thanks for the info. On a normal car I could probably run a cable from the battery to the compressor. Yes, on a normal car. This is Morris, he doesn't like normal, does he? ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
So, any suggestions where I may find a positive contact point to use? Also, if this is any help, I found the compressor relay switch, but I'm not sure which cables to connect and bypas the relay so the clutch engages.
Eskr
Eskr
you dont fill with gas to check for leaks.............,
you place the system under a vacuum , and if it holds, then you have no leaks
then whilst in vacuum and holding , you open the system to a bottle of the desired gas which is sucked into the system under the vacuum
adding gas is expensive just to have it leak to atmosphere if the system is faulty
plus, here in the UK and probably internationally it is illegal to knowingly let CFC's and such like into the atmosphere , and only a licences operative should work on the system
BB
BB
Eskr
Eskr
Sooo...I got my AC working! But Morris wasn't going to let me do this without a fight!
First thing was finding a positive point with which to engage the clutch. I found a always-on (hot) wire on a big relay with five connections on the driver's side under the hood. Made myself a male-female wire harness to go from the live wire to the clutch. The other connection to the clutch was also a wire I made going from the compressor to ground. Just for laughs, Morris decided to let the live wire touch the body, sending sparks flying and scaring me. Nothing damaged, though.
I vacuumed out the system, and much to my joy, it held pressure! Yes! Success! But this being Morris, this was only a set-up to a let down. I removed the vacuum hoses, and wouldn't you know where there was a leak? From the friggin' high-pressure valve. Laughs to be had all around!![Icon Crackup](https://www.jaguarforums.com/forum/images/smilies/icon_crackup.gif)
After replacing the valve, though, all was well. As a bonus, apparently the auxiliary fan is now working too! So now both Morris and I can be cool as summer approaches.
Thanks to all of you for your input. Let's see what I should work on next!
Eskr
Eskr
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
