Engine and box out of car
Assuming V12 Brinny:
Greg
- Camcover gaskets and half moon seals
- Sump and sandwich plate gaskets unless bone dry
- Under the sandwich plate (if it has to come off) are the oil pickup and delivery pipes. These have O ring seals which harden and leak. renewing these is easy to do and if you use Viton O rings they will last forever.
- Clean the V
- Renew the oil pressure senders
- Check cam oil feeds for leaks and renew copper seals if needed, but CAREFUL as threads very short. Better banjo bolts are available, just seen some advertised on Ebay.
- ? renew starter motor if the original is still on the engine
- Belts, fan clutch
- Replace the manifold balance pipe hoses and the coolant crosspipe/filler spout hoses with silicone (just buy a length of the diameter you need from Viper and cut to length)
- Renew thermostats if not yet done
- renew all vac hoses with silicone vac hose
Greg
jomo
11-15-2016 03:30 PM
Hafrod
05-06-2016 08:34 PM
Darel
03-27-2012 06:06 AM
SEBZX79
01-07-2011 06:28 AM
