engine idling around 2300 rpm?
Received 10,888 Likes
M90power (03-20-2012)
You'll want to redo all the vac lines on the pass. side. You can't see 90% of them, and when I pulled mine out they were in horrible shape - paper thin, rotten and extremely soft. My vac regulator was making a honking noise because the vac line feeding it was "breathing" - it was so thin and soft as soon as the vacuum would build it would suck shut then it would release itself somehow (maybe it sucked open a larger hole? dunno) so it was making this rhythmic honking noise.
Redo EVERYTHING under that passenger's manifold. My car ran a lot better when I did. This should be a very high priority for anyone buying a new XJ-S, from an emissions and a drivability standpoint.
D
D
M90power (03-26-2012)
D
D
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
JameyXJ6 (03-28-2012)
Greg
For reasons I can't recall you're not supposed to send more than 11"Hg vacuum to the vac advance, which is why they had it on that orange vacuum regualtor hanging under the pass. manifold. Kirby mentions in his book that he once removed all that junk, and then ended up putting it back on. File that one away for later...
m90 yes thats mph, because i was being followed in my friends f150 because my speedomoter wont work so he needed to estamte my speed. first world problems with expensive transmission swaps. yanno
i two eliminated everything but the vacuum advance, which i neatly mounted right up at the front all next to eachother and convient, pics when i get home. i believe the line should go underneith because that is affected by the throttle? i dont remember how i set it up but i used the diagrams.
