Brad
Hire or buy a decent engine crane, plus an adjustable balance bar to allow you to control the angle of the extraction. The engine and transmission together are about 750 pounds. The engine will come out FAR more easily if you have removed the front subframe as a unit beforehand. If the exhaust downpipes are intact and on the engine manifold still, you will have to unbolt the rear V mounts from the chassis rails to get the lot out, as the flanges on the downpipes jam on them. Once out, you are amazed it could all be stuffed into the engine bay!
This pic shows what i used:
