Engine Won't Start ???
Guest
Posts: n/a
[&o]I need your help. MY '96 XJ-S engine really needed to be cleaned. I took out my trusty pressure washer, some degreaser and I now have a nice clean engine. However it won't start. Any suggestions were I might have water that I can blow out or air dry?
Certainly won't do that again!!!
Thanks, Don
Naples Florida
Thanks, Don
Naples Florida
Hey pal, I would hope that you disconnected the battery before doing this. Either way, could you specify a little more. Can you hear it crank? Are you sure you have fuel? Does this car run on a distributor and spark plugs, or on coils? Did you cover the alternator with a bag before starting? Let us now a few more details.
Probably a matter of letting it sit for awhile. No cap or rotor. I doubt it's the coils. As Biggie asked, are you getting any attempt to turn over but it won't fire or does the engine not want to turn. Either way, it's probably a matter or letting it sit and dry out.
