Eurolat - Front suspension axle assembly
The following 7 users liked this post by eurolat:
Asdrewq (07-29-2018),
Doug (07-29-2018),
Fla Steve (07-29-2018),
JigJag (07-29-2018),
leo_denmark (07-30-2018),
and 2 others liked this post.
I was all clear.![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Great job! No one cheap parts is.
I watched the video very carefully.
What is the white grease?
I was not see water shield between bearing seal and vertical link.And typically bolt of shock mountig bracket with the nut is down side.
With a box full of parts for this job taunting me from the shop I really appreciated this post! No, I couldn’t understand the narration but I could follow along just fine. The video is shot very well, with consistent angles and lighting that makes it eminently clear what is being done. There were points I wished you’d used a headband, tripod or assistant to hold the camera so that you didn’t have to do work with one hand. That always makes me frustrated, as I want to help you, but can’t.
A very helpful and and clear piece that is like watching someone do the job from an armchair in their garage, in Eastern Europe.
Edit: I want to compliment your precision in assembly!
macdoesit (07-31-2018)
Maybe later, I will try to make english subtitles.
It is ceramic grease. And in video 1:20 used : Nivea hand cream ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
When I disassembled the axle, it had not the water shield between bearing seal and vertical link.
I think, but not 100% sure :
the wheel hub with abs sensor rotor don't have water shield and hub oil seal have code cbc2858
but wheel hub without abs sensor rotor must have water shield and hub oil seal have code c45711
innzane
10-24-2017 04:04 PM
adam699
02-20-2012 04:13 PM
