exhasut "olives"
JCR
FYI the only place "crush olives" are used on the XJS is between the top of the downpipe and the cast iron manifold. This is the parts I am referring to:
https://www.ebay.co.uk/itm/JAGUAR-XJ...cAAOSwueJbT2H8
Jaguar ones are the best, but unbelievably are NLA from Jaguar themselves - in spite of the fact many different Jaguar models use them. You can still pick genuine ones up on ebay etc though.
Thanks for the input guys. Just finished up the left side exhaust today. I didn't "crush" the olive, but just firmly tightened the flange bolts, and that was enough to seal things. So I now have the stock exhaust on the right side, and an electric exhaust bypass and new muffler on the left side. I've got the parts on order to do the same for the right side, so it should all be complete before it gets chilly here.
Regards,
John
1987 XJ-S V12
Regards,
John
1987 XJ-S V12
exhaust olives
Not sure what's going on. I've tried to upload photos four times. The last time I resized them to under 500KB JPEGs and it still wouldn't work. I can import them into the attachment editor OK and add the captions. When I hit the UPLOAD button, the attachment window goes away and that's that...nothing.
Any thoughts? It worked fine for me just a few days ago.
Thanks,
John
1987 XJ-S V12
Thanks,
John
1987 XJ-S V12
Hope these pics go through.
Thanks,
John
1987 XJ-S V12
Both the exhaust cutout and the cutout switch assembly are Summit Racing products. I've not done the wiring yet, thus the hanging cable. The angle of this photo makes the cutout motor assembly look much lower than it actually is. The stock exhaust setup can be seen in the background.
I doubt that I'll find a premade tailpipe to divert the exhaust gas down, so I may have to make one myself. It's a pretty tight fit in there. I'm not all that great of a welder, but nobody will be able to see it anyway.
My requirement for shopping for a new muffler were simple, as short as possible with offset intakes out outlets. I was afraid that they might turn out to be too loud (in non-cutout mode that is) but they are no louder than the stock mufflers.
Thanks,
John
1987 XJ-S V12
Newjag
02-04-2019 12:10 AM
abonano
01-07-2015 02:20 PM
JimC64
02-12-2012 06:05 PM
45Wheelgun
10-05-2011 03:44 PM
afonda
03-08-2011 01:48 AM
