exhaust manifold gasket substitute
has anyone come across a suitable substitute for the exhaust manifold gaskets? these are the donut gaskets from manifold to the down pipe.
ideally something i could pick up at a local parts store, rather than waiting for shipping.
parts numbers:
ebc9388
ebc4881
or
cbc4834
#3 on the diagram:
Exhaust Pipe and Catalyst-Front-5.3 Litre - Parts For XJS from (V)139052 to (V)179736 | Jaguar Heritage Parts UK
parts numbers:
ebc9388
ebc4881
or
cbc4834
#3 on the diagram:
IMC 224 26013 534
WD EXPRESS 224 26013 534
Fel-Pro 23590
AutoZone 23590
JAGUAR C184051
BECK/ARNLEY 039-6006
http://www.autozone.com/gaskets/exha...et/344046_0_0/
Fel-Pro 23590
AutoZone 23590
JAGUAR C184051
thanks scrollin.
i may just bring one over and see what they have. i was expecting these to be some unique thing that could only be obtained from jagbits or wherever.
paul, thanks for the ideas, but i was hoping to get to this this weekend. didn't think i'd have the time on saturday, but, turns out it do.
thanks again.
DrS
thanks again.
DrS
Rock Auto has them. Readily available part. If you like to spend $$ go to the "usual" suspects for Jaguar parts. If you like to save $$ on the same parts look at Rock Auto, Auto Parts Warehouse, parts geek and even E-bay.
http://www.ebay.com/itm/Exhaust-Pipe...72b1be&vxp=mtr
Received 10,886 Likes
I'm with Greg on this one.
If your car still has the originals take a good look at the construction. You'll see why the true OEM replacements are $12-$14 versus $3-$6 for substitutes.
Worth it? Probably, considering that replacing them is not exactly a walk in the park on a V12...especially on the steering side.
I've only ever seen these in a material softer than the pipe, which is why they work.
XKS.com sells them for $1.97, so I don't believe they are fancy $15 gaskets by any means.
Unless it is already apart and up in the air, I agree it isn't the easiest thing to do, so I would probably order the part from XKS, welshent, SNG, etc etc and wait a few days. Only extra cost will be shipping
I purchased four, then repurchased two more after I found that two of them were slightly too large to fit!
The ones I received as a replacement looked different than the first four I received.
The first four all had a black graphite looking substance on the inside circumference of the donut.
The second pair I received did not have it. You could plainly see the metal seam.
The first four came from britishpartsuk.com, the second came from Welsh.
They both work. They both seem to do the job.
Woznaldo
09-26-2015 11:02 AM
