Exhaust smoke
Hello, recently I have began driving my 87 xjs he quite a bit more often and one day had it idling in my driveway with my garage open while I was moving some things around. The exhaust was blowing in direction of the garage. The fumes from it where quite intense and would make my eyes burn a bit. I assume it may have been that way for a while and just noticed it. The exhaust is barely visible so I never thought it ran rich. It is a catalyst equipped us model with them intact as far as I can tell without disassembly and visually looking at the ceramic brick. The rest of the emissions equipment is present as well. I'm not sure where to start looking for the cause. Could the ignition timing be off?
Firstly, letting these engines idle doesn't help much
The V12 is there to be driven. Give it an Italian tune and then give it a smell... I assume it is just the standard cold start enrichment. When drivrn carefully, the cats 'clog' and it stinks a long time...
I'll try that thanks. I never really have gave it a proper Italian tune up, speed limits and all. It rarely sees over 3000 rpm so that could be a factor.
Usually both....
xjrwithproblems
08-10-2019 07:30 AM
