Ez-tcu ,transmission control, 4l80e
The device is connected, everything works.
BUT
I do not understand how to properly adjust
I need a smooth shifting transmission.
Now gearbox works like this: if the throttle is more than 30% and more than 2500 rpm shift very firm.
like a kick in the *** every shift. My head does not stand up.
But if 20% throttle and 1500 rpm, she is like a little cat, gently and smoothly
BUT
ronbros (08-19-2014)
Out of the box it calibrated this way for the safety of the transmission.
You need to calibrate it to the requirements of the V12.
see page 11 of this doc
http://news.compperformance.com/Instructions/302820.pdf
maybe this way...
https://translate.google.com/transla....pdf&edit-text=
maybe this way...
Nothing helps me
Today connected manual mode. This is much better, but at full throttle shift still firm.
Of course stock computer works much better. But it can not be adjusted.
I already bought a low gear 2.97, full repair kit and additional transmission. This is a project for the winter
Does not work. Pushes all the time. No quiet ride. Once is not tried. It's like a triple or more sport mode on the stock TCU.
Two weeks drove and tried to set up.
Tech Support TCI plainly does not answer.
Today moved the stock computer. The man who programmed it, is a genius.
Gently and smoothly shifts gears, no jerks, no unnecessary gear changes.
What is it, I did not find information about this 6x.
I think that already want it 6x.
What else to spend the money?
Received 1,236 Likes
the good part about money,is there is always more where that came from!
think about it ,we damn sure are not gonna take it with us.
i'll see if i can find the info on the 6by6 6speed GM auto, modded from a 4L80E.
GM does make a new 6 speed atuo but the electronics have not been hacked YET!
and it is refered to as a 6L90E, google wikipedia GM transmissions.
xjsv12 (08-26-2014)
aholbro1
08-05-2021 05:02 AM
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
