Facelift Air Conditioning - Can it just not cool well on hot days?
#41
#42
#43
Recently on a road trip, I used some small flex hoses, and piped them into the rear AC vents, and then attached the other end near the headrest. Now I have cooler air flowing to the back of my neck. These AC units are weak, and mine has no leaks. Granted I have 200k plus miles. Cold air comes and goes at times too.
#44
Not sure if it is possible to adjust compressor clutch air gap on these compressors used on Jag. If air gap gets too big, usually 1mm and greater starts creating problems especially when you need full performance. It may click on/off fine, but when everything gets hot clutch starts to slip. Later on it will loose grip more and more, and propably compressor on/off sequence go wrong too -> no full power from a/c.
We have had 30-34c degrees heat wave here in Finland too. XJS is doing well, lady in the house said her swedish brick didn't cool well enough "do something NOW"... adjusted compressor clutch air gap and got better cooling. (this car/compressor is well beyond its "best before" date, but as Volvos tends to do, it just keeps on going)
#45
#46
#47
Usually it is done by removing shim(s) from clutch assy. First thing is to measure gap between pulley and freely rotating clutch disc, if it is close to or more than 1mm it needs to be agjusted down.
Good overall gap is somewhere around 0,6mm.
This is not from Jaguar maint manual etc etc, just very general info which works on most compressors with magnetic clutch.
Removing shims means removing clutch front disc, usually it is held by center nut, after nut removal disc needs to be pulled out. Usually it needs puller which pulls disc off against center shaft.
Again, not sure if this works with Jaguar compressor and insufficient cooling can be something else too.
Just one easy thing to check out.
Brewtech (06-26-2021)
#48
#49
As a general point: If you have the Delanair III, then it has a manual mode, the temp control can be pulled outwards, and this provides full cold.
For a short while, I had a 3.6 Coupe with the Delanair III, 1990 model. In this mode it would absolutely freeze the car. So if your car will not do so in manual mode, then the system is definitely not up to spec.
#51
Last week, I took it to my Local Indy Jag mechanic and he decided to thrown in some R134 in it and I suddenly have the best cold air that its ever had. Ive also retinted the car with ceramic tint, including the windshield. The car is a pleasure in this heat, now. Thanks for the suggestions.
Greg in France (07-18-2021)
Gary Bokelmann
37
06-04-2017 10:13 AM
WinterJag
05-18-2012 12:38 PM
equicor
06-25-2011 01:32 PM
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
