Facelift Convertible Top Leaking
So the OEM top is finally letting in some water. It goes directly into the housing that holds the handle, so the car is dry until I drive it and hit the brakes, then the water comes spilling in!
Anyways, I suspect its coming from a thread line that is no longer there. The tiny holes can be seen when there is sun behind it.
Any ideas for a temp solution to get me to the wintertime?
I didn’t realize an ice cold splash when going down hill wasn’t standard equipment. I get it at the end of the driveway…. Right on my pant leg. The stitching is all still there! But for the other wear holes and complete rips, I used as seen on TV flex seal tape. There is a complete rip side to side across the top cause by… well… an overweight barn cat that thinks an XJS roof makes a great hammock. It’s been taped up for two years. The top is regularly put up and down and it hasn’t peeled off yet.
