Facelift Knee Bolster Passengers Side Clip
I've been hunting for a replacement clip for the knee bolster on the passengers side of the car. Part Number JEP113005.
I thought I found a matching part to a 1968-1972 Chevelle. It sure looked to be the part, but it isn't. It's too small.
The part I came across is 9508010 called a Console Clip, or Wiring Harness Clip.
If you need this part hoping it will work, it won't. Looks like I'll probably have to make one? How hard can it be....
That would be most helpful!
(figured I'd post it here for all to see)
Dammit!! I posted the picture of the broken one. For the first picture, pretend the metal bends back 360 degrees and comes back, parallel to the tape measure at that part that bends closest to the tape. (Does that make sense?) The part furthest away from the tape is fine, the part closest to the tape broke off.
xjsv12 (01-31-2018)
I had a problem with the knee bolster panal falling down and hitting me in the shins and it did hurt. The thing just would not stay up. I figured it would be impossible to find replacement clips so I cut a strip of tire inner tube rubber and placed in in the opening of the clip and pushed the panel into position. So far it has stayed where it belongs.
