Facelift Rear Springs Description
I'm posting this for anyone looking to find an alternate rear spring for the facelift XJS, non-sportspack models.
The spring is 11-5/8" tall
It is 3-3/4" wide
The coils are 11.7mm thick
The coil is made up of a total of 9 complete turns.
Perhaps this can help someone in the future?
It is 3-3/4" wide
It is 3-3/4" wide
It is 3-3/4" wide
Thanks.
I'm going to add this link to this thread in case anyone is ever curious about spacer effects on the front and rear ride height. (SPOILER ALERT: Apparently you get a three-fold boost on shims. A .125" shim will raise your car by .375")
https://www.jaguarforums.com/forum/x...spacer-214236/
ptjs1 (03-17-2021)
It does depend what the spring compression rate is Vee. They might be OK. If not there are loads more to your spec on sale in the UK.
