Facelift Trip Computer Problem
My trip computer is acting strange. It reads everything at a reduced rate. It also seems to be freezing up as well.
It's definitely set up for miles, but when I'm doing 55mph, it shows that I'm doing something in the 20s.
All of the other features are whacked out as well.
The clock feature seems to be working just fine.
Is there a fuse or some relay I should or can check? It's a 1996 XJS.
Thanks.
Thanks.
On my MY94 trip computer, the speed display is average speed since last reset, if yours is the same then that's why it reads lower.
Press and hold the reset button until you see 00:00 to reset the data. When you hit reset you must not be on Time display else you'll go into clock setup mode.
Cheers,
Allan
Cheers,
Allan
