Facelift Windscreen/Windshield Fit
Old 11-22-2021, 11:52 AM
ptjs1's Avatar
Received 3,081 Likes on 2,037 Posts
Posix,
I presume you have a Coupe, rather than a Convertible? BEC9535 is the seal for an early facelift Coupe. As you probably know, the screens are different thicknesses on Coupes and Convertibles, hence different part numbers for each body type seal.
I don't know if it helps at all, but I've attached the Jaguar workshop instructions for the removal and renewal of the screen and trim. There isn't a 3-dimenisonal diagram though.
Good luck
Paul
Old 11-22-2021, 12:53 PM
Posix's Avatar
Originally Posted by ptjs1
Posix,
Good luck
Paul
Paul yes an early facelift coupe and that's exactly what I needed! You wouldn't happen to have a higher res version of this?
Old 11-22-2021, 01:04 PM
Posix's Avatar
Well, no not really, they in essence say "remove and then reverse". I was hoping for a more detailed explanation of how the bec seal goes...
Old 11-30-2021, 02:33 PM
Posix's Avatar
Here's my "codes" if anyone can decypher what they mean and if this is the correct windscreen for my car vin 180020, dots above L and below d
Old 12-01-2021, 11:09 AM
Brewtech's Avatar
Finding a windscreen was nearly impossible for me here in Los Angeles too, so I settled on a Chinese made unit that fit perfectly and to my amazement it doesnt have one bit of distortion and the price was a third of an original one that required an additional shipment fee. I reused my seal but I might have to replaced it in 10 years. 93-96 coupes use a slighter taller windscreen and outer seal I believe. The seal covers the outer edge of the windscreen and the steel trim. It essentially keeps moisture out so there should be no spacing.
Aloha Bob
10-16-2019 09:31 PM
coleman645
09-02-2018 10:29 AM
renaultvation
02-19-2014 02:21 AM
sherbercars
08-06-2011 03:20 PM
Quick Reply: Facelift Windscreen/Windshield Fit
