Fan shroud mounting question
Received 10,916 Likes
Hi !
Take a peek at this illustration and note the mounting tabs at the top of the shroud.....
Cooling Fan Cowl-Mechanical-5.3 Litre - Parts For XJS from (V)139052 to (V)179736 | Jaguar Classic Parts UK
Here's my question:
Should there be rubber cushions at those mounting points? The illustration doesn't show any, and frankly I don't recall removing any. But I have a nagging thought that those holes should have those round grommet-like cushions as used in various other locations.
Thanks for any help
Here's my question:
Thanks for any help
Doug (05-16-2016)
Hi !
Here's my question:
Thanks for any help
Here's my question:
Thanks for any help
No rubber mountings on mine and the Shroud has never been out.
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1333/img_3188_5e7e993ec23ffc37f7e1370abc62377ceb905566.jpg)
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1333/img_3189_3b74a333e1265fa189d04e139606d1ecc3cfb1fe.jpg)
Doug (05-16-2016)
orangeblossom (05-17-2016)
On my 1985 the shroud fixing holes had rubber cotton reels OEM. The holes on the shroud fixing brackets were quite large, and without the rubber and a washer on top before the fixing nut, the shroud would have fallen off. Maybe it was changed at some point?
if you have an main electric fan in place of the engine driven one, attached to the shroud, some sort of damping is quite useful to prevent vibrations into the body.
Greg
Greg
The following 3 users liked this post by Greg in France:
Yeah, the large holes are just begging for the 'cotton reel' mounts! That's why I had to ask !
But.....
The large holes, left rubberless, give you quite a bit of adjustability when positioning the shroud
I'm going with 'rubberless' mounting on the shrouds themselves
Cheers and thanks
The following 2 users liked this post by Doug:
Grant Francis (05-17-2016),
Greg
The e-fan assembly is mounted to the 3-leg bracket using the rubber cushions, and the bracket-to-shroud mounting uses the rubber cushions as well.
orangeblossom (05-18-2016)
FS[Western US]: Parting out 1997 XK8 convertible
BobRoy
49
09-18-2016 10:48 AM
Uncle Fishbits
03-24-2016 06:20 PM
