FI Harness update
FI Harness update
It's built and installed!
Building a new harness isn't difficult, just a little tedious, but, worthwhile and satisfying. It looks daunting, but take notes and pictures and you can't really screw it up.
I bought all the parts from Del City and I am very pleased with the service I received from them. I highly recommend them. I routed the harness from the rear as has been suggested. Made things a little neater looking. For a connector I used a 5 way trailer light connector from NAPA, about $6. The connector is sturdy, weather tight, and about 2" long x 1" wide x 3/4" thick. Very compact and made of hard rubber, it also comes in a 6 way of the same size. Just by coincidence the wire colors matched the colors I used on the harness. Go figure! $130 total.
While I was at it I removed the fuel rail and injectors. I sent the injectors to Jaguar Fuel Injector Service and had them tested, cleaned and serviced as needed. Service was excellent and a week and a half turn around California to Florida. I highly recommend them also. $305.50 total
I also replaced all of the fuel lines under the hood, changed the air filters and changed the oil and filter.
I turned the key yesterday afternoon and voila, it fired up and runs smooth. All things considered it was an enjoyable and rewarding project.
I especially enjoyed building the harness. How many Jag projects can be done sitting comfortably at the kitchen counter with a cocktail, or wine or beer if you prefer, within reach!! Damn, I may go into business.
Now I have to address a trans fluid leak that appeared just before I put the car in the garage for the FI redo. The leak appears to be between the trans and engine area. I didn't notice anything obvious and really couldn't tell whether it's migrating or just dripping straight down. Bummer, no more bar stool, back to the concrete floor!!
I built my new Marelli harness myself, from the Marelli ECU out. I did mine on the car. The harness that was on the car had a great amount of extra wire, and duplicate wiring that served no purpose at all. A little time, a little wine, and as you say, it turned out great. A very rewarding project.
Scott,
I can't send a pic of the harness as it is already installed. The original harness is like supercharged said, it has way more wire than necessary and is overly complicated. I ended up using 6 wires and 5 colors and putting it all in 3/8" loom.
My Del City parts list consisted of:
16 injector solenoid connectors #73522 $1.31 ea. ( i always buy a spare or two)
100' of hi temp split loom #774 $18.92 I'm not sure the high temp is necessary, this is 100' minimum, you can get split loom at Fryes, O'Reillys etc.
100' each of 16ga. GXL cross link wire at $11.78 a spool. 100' is minimum order.
Blue 4116103
Yellow 4116106
Green 4116104
Black 4116105
Red 4116101
White 4116102
Brown 4116107
I ordered all 7 colors just because that's how many they had and it doesn't hurt to have extra wire around.
I also used the 5 way trailer light plug from NAPA, very compact, sturdy and weather proof.
I don't know how to post pics but if you pm me I can text a pic of the scheme I drew up for the new harness.
Terry
The Marelli harness had several circuits doubled back to points that could have stopped far earlier. My car is a late 89, which only had coax going to the engine speed sensors. I opted for the later style, where coax went to the amps too. My harness is FAR smaller, less complicated. I just used the wiring diagram, started one circuit at a time, to its point of destination, and kept at it. At first, its overwhelming, but once you do a few wires, even having to unsolder, resolder a new way due to something you figured out along the way, it gets less and less daunting. I used a cheap soldering iron, and lots of patience. Had never done it before, and it worked out great.
It hasn't been mentioned yet, but I bought heat shrink from my local Pep Boys in a kit of several various sizes, and a cheap heat gun. I had to undo a couple of my connections, would up buying another kit because I ran out/low on two of the sizes, but it really does look great if I say so myself. I could take pics if you wanted them, but I doubt very seriously you could tell anything from the pics unless you had very good shots of a original harness bay to compare it to.
I have found this website Jaguar Wiring Harnesses By Macharness
You can see how many more wires are in this harness. I would recommend rebuilding the FI harness and then soldering them into the rest of the harness. Assuming the rest of the harness is in good shape.
