Filling the Radiator of a 94 XJS 6cyl
Old 11-07-2016 | 08:27 PM
dtony's Avatar
Default Filling the Radiator of a 94 XJS 6cyl
HI all,
Just curious if there is a trick to filling the radiator of a 94 XJS with the JAI6?
Any info is appreciated.
Tony in NM
Old 11-08-2016 | 03:46 AM
ptjs1's Avatar
Tony,
AJ16 XJS is very easy to fill, much more so than the V12.
With ignition on and heater control set to hot, fill from cold through remote tank, let it settle, aid the bleeding by pressing the multi-branch lower hose a few times. When it's all settled, start the engine with the cap still removed and let any residual air burp itself through the tank as the water flows through the system. Seal Cap, bring car fully up to temp. Let it fully cool, remove cap carefully and check level.
Good luck
Paul
