Final drive unit overhaul
Hi, I'm new in this forum!
I started to renovate the differential on my XJS 5.3 1984. (2.88:1 ratio) I wnat to change pinion and crown wheel bearings. I need a tool to measure the pinion height. I have measure clock, but missing the target of the round iron block I need to adjust the clock after for adjust pinion height. I would be glad if someone here in this forum which has the height og the iron block så I can make one? Remember that it is a Differential. with 2.88:1 ratio - not a Dana Differential!.
Hope there is someone who can help me
Sincerely,
Per
Sincerely,
Per
