Finally got my car up in the air
Looks like a pretty typical XJS, a little rusty, and crusty around the edges. I didn't see any major rust through, but I'm sure once you start knocking all the surface rust off, you're gonna find several weak / thin spots. Being that it's a 76 your's is in better shape then a lot of them. I have 2 - 89's one is a little better then yours, and the other is a total rust bucket. It's so rusted the passenger side, front jacking point crushed when I tried to lift it up on my lift, it's so bad I had to take a piece of 2x6 and put under the frame to lift the car up to inspect all the UGLY. Your's is in good condition for a 76. Good luck with it.
Jack
Jack
Kris
The bodywork under that car looks absolutely shot. I respectfully disagree with Jacobra, I think getting it back to structural integrity will be a major and long job. There is a huge amount of structural welding, particularly on the seams and round the rear axle that needs doing; I am not saying it cannot be done, rather that but the task very substantial. After that all the mechanics need doing, including fuel and brake lines, all rubber components, and what is the interior and wiring loom like?
Unless you really want that challenge, and good for you if you do, I would seriously consider buying another in better shape.
The following 2 users liked this post by Greg in France:
orangeblossom (06-03-2019),
petemohr (06-03-2019)
Kris
Greg in France (06-04-2019)
Thanks Steve, yeah as little as these cars are worth, they are a hell of fun to drive, Insurance and registration is dirt cheap, besides keeps me busy and out of the bar, and the kid off the streets. And every piece of electronics I can remove, and the car still runs, it makes it that much more fun..
Can you replace the electronic fuel pump with a mechanical fuel pump - or does the engine mount get in the way?
Mechanical pumps are more reliable than electric - low PSI required for a carby over fuel injection, and you don't need a inertia switch. Would remove some more electrics
Steve
Steve
If it was my car Id corroseal ALL of that, then blast it off with a sandblaster and a 5gallon bucket of baking soda, a very fine blasting media. Corroseal rust converter
JaguarXKR
07-13-2013 01:44 PM
rpolizzano2013
07-12-2013 01:40 PM
frombenz2jag
24
01-03-2008 07:07 PM
