First V12, First tune up
Just purchased a Burgundy 92 XJS. 76k miles. It runs great and shifts smooth. Everything seems to be in good working condition (except a/c) I'd like to keep it off the road for a couple weeks while I perform a good tune up and I need some suggestions from you veterans... Here's a list of some of the things I'll be doing and some questions to go along.
-Oil change (what brand and weight do you like to run?)
-Cap and Rotor (reliable brands?) I'd like to avoid any fires. This car is hot enough
-Radiator Flush (any process tips?)
-Thermostat change (what temp/brand? I've seen two different kinds) keep in mind I live in Texas
-Fuel Filter
-Air filters
-Belts
-Tranny filter and flush (is it easily accessible?)
-Fuel hoses
-EGR valve clean
-Brake job (easy enough or nightmare waiting?)
I just need answers to the ones with questions or suggestions on more to do while i'm at it. I appreciate any input
-Fuel Filter
-Air filters
-Belts
-Fuel hoses
-EGR valve clean
Need a little more info 1992 is the facelift model is yours 5.3 or 6.0L, some of the 6.0L had a version of Fords EDIS so do not have distributors.
Check in the V to see if it has a distributor if so it will be Marelli ignition. I pulled my cap and rotor a couple of months ago and they were good just gave the rotor a clean and put it back together.
I would pull the plugs and check them especially the hard to get to ones under the AC compressor.
Brakes should be a snap as it will have outboard rear disks.
I would not bother replacing the thermostats unless you have an overheating issue and everything else has been done first.
Does it overheat? if so I would pull the radiator and have it rodded or recored, if not I would drive it no point in fixing something that is not broken, you can create more issues than you solve.
I use Nulon oil cant remember what weight but it was as per the book. Be prepared to buy a lot it holds 10-12L from memory.
AsherDaze (11-01-2011)
Received 10,988 Likes
Assuming a V12 engine you want 20/50. Any name brand is OK in my book.
Again assuming you have a 5.3 V12 you'll have Marelli ignition. The genuine Marelli cap is out of production. As of a year or so ago the genuine Marelly rotor was still available from Jaguar. I've seen three aftermarket caps all made by the same [unknown] manufacturer but sold under different labels
Are you familiar with the bleeding procedure?
82ºC or 88ºC....you decide :-). The V12s 'stats are unique. Can't use a generic. Get one from a Jag vendor who knows what to sell. "Waxstat" is OEM...and what I'd ask for, personally.
Dropping the pan means dropping the exhaust so plan on extra time :-)
-Fuel hoses
Good! 12 injector hoses plus the supply and return hoses, right ?
-EGR valve clean
I never knew the V12 had an EGR back in '92! Learn sumthin' new every day !
Fronts are easy. Rears are easy if only pads are being replaced. If you need calipers and rotors it's a big project. BIG project :-)
Yes it's a 5.3 with a distributor. I've read the link on this site to "accessing the V" and plan to go that route to reach everything. No overheating problems. I just thought it would be nice to get most of the preventative maintenance out of the way before i turn this car into my daily driver. I see your point though. Thank you for a quick response. Any other suggestions on the tune up?
Thanks for breaking it all down for me Doug. Your responses are always so helpful. It might not have an egr lol. I'm sure you know WAY more than I. To answer your question, no i do not know the bleeding procedure. Do inform me And I'm not sure about all the hoses. If I remember correctly I didn't see hoses to the injectors but I may be wrong. I thought 92 was the year they stopped using the hoses. Thanks again Doug!!!
Hoses: Might be that I'm wrong, not you. I forgot that the injector hoses were eventually eliminated. Not sure when. If you have 'em they're only about 1.75" long at each injector.
I posted a bleed procedure. It's in the archives somewhere. A search with "cooling system bleed" as keywords oughta do it.
Fuel Rail hoses
I also have a 92 XJS and the fuel rail sits directly on top of the injectors, as such it eliminates the short fuel lines that would always dry out and leak. My 90 has the short fuel lines and they are stiff and need replacement. Be sure and flush the cooling system to remove any sort of "krud" that may have found a home in there. I also had an overheating problem which ended up being bad thermostats. Fortunately I was able to get generic "stats" from AutoZone and replace my old ones. By the way AsherDaze, you will love having an XJS as they have such class and are frequently mistaken for a Ferrari until someone gets closer and then they drool on your car. Carry a quality rag to wipe off the drool. Burgundy is a beautiful color for an XJS. As to doing a radiator flush, I pulled my radiator out of the car to be sure it was done right. That may be a bit "over the top" but you NEVER want to overheat one of these cars. If you can, post some pix so we can see your new "delight".
FS[Western US]: XJS V12 Convertible
marklcap
09-29-2015 12:41 PM
