I would drill out the rivots to remove the frame. Then remove the plug from back of frame. You may need to cut a hole for the wiring on new deck to fit. Then rivot it back in.
As for the wiring just meter it and match to new deck. The old frame wiring may still have tags on wires.
Hi BC
I had a bit of a feeling those rivets might have to come out but was wondering how far the Cage pulls out to unplug the Plug on the back of the Cage.
Then when I unplug the Plug from the back of the Cage, I'm hoping that the Plug will plug into this Adapter (see photo its the white Plug not the black one)
I should have plenty of room behind the Stereo as this new one is only half as deep as the old one.
Will the Plug on the back of the Cage plug into the 'White' Adapter?
Any idea what the Black Plastic Box on the back of this Cage does?
Its stuck on with some sort of Super Glue, does it need to be in contact with the Cage or can I cut it off with a knife between the Black Box and the Cage.
Bear in mind I may want to Retro Fit the Old Radio one day.
What does the Black Box on the back of the cage do, as its still connected to the Original Plug.
I guess I may as well re-use it then, as I am going to need an In line Fuse Holder anyway and that's the only wire that I will have to cut.
All the other wires are on Bullet Connectors which came as a bit of a surprise, as there was no where to plug in the special adapter that I bought.
If I re-use the Black Box does it need to be in contact with the metal on the side of the Cage, or can I just put it in the space behind the Cage somewhere?
It was massively daunting removing the old unit, so I just had to wing it and hope for the best.
They certainly didn't stint on the wiring, when I pulled the Cage out, all the wires were long enough to reach down to the floor.
