Five Volt Reference
Five Volt Reference
On later model cars there is a sensor reference that is five volts. The five volts comes from the onboard computer. This voltage is used for sensors in liew of the battery voltage which can vary because of the alternator output. Was the XJS pre five volts and if it was post five volts where is the five volt shown on the electrical diagrams?
Doug (08-13-2020)
Thanks for your reply's, This internet posting http://www.pearsoned.ca/highered/div...toTec_ch25.pdf raised my curiosity about five volt reference voltages as it applies to sensors and their interaction with the ECU.(See Page 525) A faulty five volts could as you Blokes say " Drive you up the wall;" since the five vaults regulates and reports the sensor info to the ECU.
I don't have sufficient information on Jaguar's introduction of computer controls on any of the XJS models. I have a 1993 6cyl XJS and also the Electric Manual for that year, but could find no info on reference voltages. That papacy of information made me wonder if Jag had a different system
Last edited by afterburner1; 08-14-2020 at 09:37 PM. Reason: ANOTHER REFERENCE: https://www.underhoodservice.com/making-sense-out-of-sensors/
Grant Francis (08-14-2020)
afterburner1 (08-17-2020)
I doubt it has any reference to the pins.
3CU, D Jetronic, had more than 3 pins..Schematics somewhere, but not needed.
6CU, Early He, had more than 6 pins. 22 in fact.
16CU, later HE, had more than 16 pins. 22 also.
36CU, same size physically from memory?, so probably 22 pins also.
It is a "Model ID code" as best I know.
Greg in France (08-19-2020)
Um, dunno,
As a pure wild stab in the dark, CU could be "Control Unit", and the numbers the generation of same as they improve (haha) and alter things, a new number creeps in.
All I do know is the 16 was more stable than the 6, and also processed the data 5? times faster than the 6. All the 6 units I have replaced with the 16 (plig and play) did improve the engine, and it was noticeable to the human ear, not any machines, which I dont have.
Never thought about until now, and its gone already, oops.
Greg in France (08-24-2020)
Grant Francis (08-24-2020)
James,
Great dissertation on CU's (CU meaning Control Unit). Since I have a 6cyl and 1993 XJS my question was not ,as far as I can see, answered. I was only looking for the 5 vt output from the ECU to the sensors. I was not sure if Jaguar had used 5 VT? Any help on that question???
Grant Francis (09-02-2020)
Greg in France (09-02-2020)
vettegood
05-05-2018 07:57 PM
