Fluctuating Oil Pressure Reading -
Greetings everyone,
My 1992 XJS 5.3L oil pressure gauge is fluctuating when I drive now. Checked oil level and it is fine; no oil leak.
I had a similar problem with my 1993 Daimler Double Six 6.0L and replaced the old unit with one that never fluctuates, but goes to the mid point of the gauge. Since replacement, its never been a problem.
Is there such a "fix" for the XJS?
Or, do I just replace C46272 with an aftermarket model? (I doubt the original has ever been replaced)
Is there another oil switch that people would recommend to be changed at the same time? If so, please provide the part number.
Many thanks,
Charles
Many thanks,
Charles
Charles,
Jaguar brought out a new sender unit in the 90s, apparently because US owners complained that the pressure gauge fluctuated (as indeed it should at times!). The new sender unit acts really as an on/off switch. If you’ve got any real pressure, the gauge just sits in the middle. It’s not ideal for those of us who really want to know an accurate pressure reading, but it obviously kept the bulk of customers happy (and ignorant of the real pressure!).
AFAIK, the part number remained the same. I still have the original on my 4.0 AJ16 and although the gauges are never that accurate, I'm quite happy seeing it go up and down depending on temperature and revs.
Paul
Paul
The following 2 users liked this post by ptjs1:
Grant Francis (09-18-2024),
orangeblossom (09-21-2024)
Greetings everyone,
Many thanks,
Charles
Many thanks,
Charles
Jon
The following 2 users liked this post by MooseOHJ:
Greg in France (09-18-2024)
Wyzawazza
04-24-2024 05:38 PM
