Foam on oil dipstick, 1996 4.0
Checking my oil yesterday I saw some brown foam-like stuff on the dipstick. I have noticed this on other cars in the past. Is it caused by water in the oil or possibly condensation in the sump? Is it a warning of impending trouble? Any thoughts are appreciated.
RagJag
RagJag
I suggest you give the car a good hours fast run and then see what evidence there is of any foamy mousse anywhere you can look.
Greg
As Greg says, foaming of the oil is not unheard-of, and is generally caused by condensation or, occasionally, a bad head-gasket. The fact that you describe it as "brown" makes me ask - I suppose the engine isn't over-full of oil, which is getting "churned" and foamed by the crankshaft dipping into it??
if it looks like coffee, its probably water. ive never seen the classic "white milky" stuff after ive gotten coolant in the oil. it always looks like coffee to me. other things will cause it to foam up as well including things like the oil being overfilled causing it to be churned up by the crank, or on an engine that lacks a windage tray, you can get some foam after a WOT pull or some hard corners.
RagJag (11-22-2012)
AJ16 engines such as yours are not known for blowing head gaskets, even in higher mileage examples, but it does occasionally happen.
What is common is a condensation on the oil dipstick tube (cant remember why) Look in the X300 (same engine as yours) archives and you will see what I am talking about .
Good luck
RagJag (11-23-2012)
Thanks to all. I am hoping it is condensatoion because it hasn't been there all this summer but now we have had some cool nights. The sump is not over filled. I changed the oil in July and all was well since then. It may be short runs around town with the coolant barely getting up to full temp. I will monitor it and hope it isn't too serious.
RagJag
RagJag
The weather is cooler and condensation in the engine more common after short runs where the engine doesn't get hot enough long enough to evaporate (proper word?) all of the water vapor in the engine. My XJS diven daily 50 miles doesn't have the goo, whereas my VDP does because of the short trips it's used for. Watch the coolant level in the overflow tank for disappearing coolant. My guess is that you're using your car for short trips in cool weather.
RagJag (11-23-2012)
RagJag (11-23-2012)
RagJag (11-23-2012)
aholbro1
08-05-2021 05:02 AM
