Fog light bulbs(what does yours use?)
Old 01-28-2015 | 11:13 AM
Jonathan-W's Avatar
Default Fog light bulbs(what does yours use?)
Hi All!
tried to go buy a fog light bulb last night.....
the store did not have or carry H2 bulbs...
then they ask me well, what year and all
I told them 1992 Jaguar XJS and they told me that I need an H3 bulb...
they were very insistent that is was an H3 and that there computer is and has never been wrong....
did not matter that I told them I took it out and held it in my hand
they said some one change my fog lights... I said No... I have the owners manual and it says it is an H2 also...
so I find that the Osram Sylvania site also states that 1992 -> 1996 uses an H3
so I know what I have (JLM 9588 ie H2 55watt hella ) what do you other 1992 -> 1996 XJS owners have for a fog light bulb...?
I called Osram Sylvania and let them know that their online database was in error regarding my model of car...
Old 01-28-2015 | 02:13 PM
88-xjsv12's Avatar
You'll need to go by the voltage/amperage and play plug n check or walk into the store and match the old too the knew.
Old 01-28-2015 | 02:15 PM
88-xjsv12's Avatar
Me personally I'm upgrading . I'm buying yellow or clear 7,200 lumen pods from gg lighting . Either this or a simple light bar
Old 01-28-2015 | 02:41 PM
Jonathan-W's Avatar
so what bulb does your XJS have in the original fog lights?
Old 01-28-2015 | 02:47 PM
Jonathan-W's Avatar
I am designing my own... based on 10 to 100 watt square LEDs
I currently and running experiments using the 10 watt and lenses I need darker sun glasses for higher wattage experiments...
I am looking to generate and nice beam patterns... that will not blind on coming traffic and put the light where it will be most useful....
and yet retain the classic look...
a brighter bulb is not always the brighter solution....
Old 01-28-2015 | 02:54 PM
Spikepaga's Avatar
Original hella Foglights all have h2 bulbs. In my opinion the H2 bulbs overheat and crack the lenses.
Since my foglights are for looks rather than for use, I made bigger holes on the back of the lenses and put H3 WARM WHITE LED's. The warm white led towers look like a stock bulb, you don't get any of those tasteless LED colors or the LED "look":
Jonathan-W (01-28-2015)
Old 01-28-2015 | 03:33 PM
Jonathan-W's Avatar
those look very nice...
Old 01-28-2015 | 03:36 PM
Jonathan-W's Avatar
previous owner, put this in upside down... it could not drain so it rusted...
here is what I was fighting to fix
Old 01-28-2015 | 09:48 PM
Spikepaga's Avatar
Any chance of soaking those on CLR can help
Old 01-28-2015 | 10:14 PM
Jonathan-W's Avatar
here is the results so far
I did not think of CLR...
I will go pick some up....
I used ("laughingly" Scope mouth wash, to clean the rubber and Q-tips to reach in and clean the lens) rinsed with 91% alcohol
new bulb and I need to check to see that it is getting power as it dose not light up...
Last edited by Jonathan-W; 01-28-2015 at 10:17 PM. Reason: include before pictures...
Old 01-28-2015 | 11:09 PM
Stargazer XJS's Avatar
I think the H2 is the way to go.
My Mark VII also used the H2 bulb, they're stupid hard to find, and neither H1 nor H3 would do the job despite the parts store's insistence. I luckily had a pair that I never got around to installing (more rust problems - I didn't want to lose a fight to a screw) so I've got them in case the Jag's fog lamps take a turn for the worse. They don't work anyway, but I somehow don't think it's the bulbs.
Old 01-29-2015 | 03:45 AM
daverb's Avatar
My manual for my 84 states H2 but when I took the bulb out it is the H3. like others, I believe the original or 2nd owner changed them or Jaguar put different type on. Mine are Bosch. By the way, my local Wal Mart carries the H2. ,
Old 01-29-2015 | 10:57 PM
Jonathan-W's Avatar
had to take a razor knife and scrape 1/32 inch of oxidation off the bulb holder now the bulb gets power...
I HAVE 2 FOG LIGHTS AGAIN...
oddly the one I worked on has a better pattern....
maybe I need to work on the supposedly good one next...
Old 02-04-2015 | 07:13 AM
Paul_59's Avatar
Banned
My 1993 facelift has H2 bulbs , don't seem to be available in most places.
I managed to find a pair on ebay
rsa760041
23
09-25-2015 01:33 PM
avern1
09-08-2015 06:25 PM
avern1
09-06-2015 04:22 PM
XCrossWindsX
09-05-2015 10:58 PM
gene1
09-03-2015 05:58 PM
Quick Reply: Fog light bulbs(what does yours use?)
