Footwell heater doors partially close
The heater doors for the footwells on my 94 XJS 2+2 will not fully close. They remain open approx. 1/2 an inch. If I unhook the vacuum line they move freely, however once the line is reconnected they once again stop at that 1/2 point. Any advice to remedy this would be appreciated.
Thank you,
Lionel
Thank you,
Lionel
My symptoms were as follows;
Switch on to low speed on the fans:- they would kick in from low to high, constantly; gentle blow to Force 12, cycling in and out.
Switch to medium; similar, but not quite the same.
Switch to high and it was Force 12 From Navarone, full force in the face and blowing your socks off at the same time.
There was no temperature change in the supplied air at all, it was just randomly blowing outside air inside, all over the place.
Check out the Forum feed for 'British Engineering!'
I don't know what the exchange rates are at the moment but I do know that over here it will cost you over £1000 to get someone to pull the dashboard out to diagnose what the problem is before they even start to fix it.
If you can live with it, then do; otherwise it will just suck your wallet dry.
If it's cold, wear a hat and gloves.
If it's hot, move to a cooler State.
I have an old boat and it had a 3 way fridge (12V, 240V and gas). It didn't work properly so I pulled it out and rodents had gotten in and eaten all of the insulation and half of the wiring. As it would only hold 4 Budweisers and a chicken burger I thought that it would be cheap to fix.
Nope, £450 (4 years ago, about $750).
Sod that, moved a bit of wood, installed a standard domestic fridge which takes 12 bottles of wine, 16 beers and ice for the Pimms; possibly some food too but I haven't checked that yet.
£105.
Focus on the important bits about the car; Jaguar only put a/c in so that they could sell it in America.
Make sure that the car goes and stops; the rest of it is icing on the cake.
£105.
Great information and a chuckle too.
On my car, which I only drive in the summer it blows full heat onto my feet. I have been contemplating unhooking the vacuum line so that I am able to manually fully close the flap and then taping it closed with Tuc tape so that it is sealed. Given the price I am leaning further and further toward this option.
How about using nylon zip ties? Easy to put on, cheap to cut off?
99xk8guy
06-05-2023 06:28 AM
