Forgive me
Forgive me
Last drive through the snow I promise!
I completed my roadtrip, averaged 15mpg over mountain top highways totaling 1700km or 1050 miles over 4080ft summit, could of done better but what fun is it when your only puttering along...better to floor it and deal with the consequences later.
Doug (01-01-2019)
Went up from Vancouver to Kamloops/area via Highway 1 (very scenic, nice winding highway) and on the return went back down Hwy 1 but detoured due to a road closure and ended up going through Ashcroft on Hwy 97c up over the mountains to Merrit and back down to the coast, also a stunning winding highway route... now that I think about it I regret not taking some pictures as the drive absolutely brilliant, clear and sunny no snow on the road surprisingly, all the mountain ranges dusted with snow and best of all nobody on the road.
I don't recommend driving this sort of car in any snow/ice conditions regardless of tires even when I had studded winters its just so poorly weighted I've had the car slide sideways at idle while on ice there is just no weight in the back to balance out the huge v12.
2519/1079 KG here. Nuts! Surprised it works as well as it does in the dry.
HA! I’m an idiot. Driving in I was thinking. No, that can’t be right. It’s heavier than that! I was reading lbs and legs at the same time. Lol.
1079 kg front and rear according to my plate. No actual weighing.
So, 50/50 F/R according to Jaguar. Is that a fact? Anyone checked?
Only when fully loaded. My vehicle papers state the car weighs ~1.7t (metric!) when empty but with 90% fuel and a 75 kg driver. The front is a lot heavier than the empty rear. Without an engine you might be at 50:50
defiantly not 50/50
my xjs witch is engine swapped with a lighter engine than the v12 is still not 50/50
1993 jaguar xjs convertible sbc swapped with 700r4 on a certified scale.
3720 lbs
with a weight distribution of
2020 lbs front
1700 lbs rear
in kgs
1687kg total
916kg front
771kg rear
3720 lbs
2020 lbs front
1700 lbs rear
in kgs
1687kg total
916kg front
771kg rear
For what it's worth, my Japanese documentation says the F-R weight split is 1,000 kg front, 770 kg rear. Unloaded for both (1770 kg unladen, 1990 kg laden though I don't know how that breaks down).
So anyway, you'd need a couple of hundred kilograms of sand or gravel bags in the boot to make it 50-50. Best to avoid ice, I think....
The XJS V12 rear end comes loose in light rain if you're not paying attention.
Mine does not do that. You can break it loose if you put your foot into it, but driving normally I have found the traction to fine. I have Nexen Tyres and these have great wet weather traction, far better than the Michelin's I had on it before.
Greg in France (01-06-2019)
Perhaps I'm always paying attention (which tends to be the case with this car), but I've only had the back break away once, and that was very slightly, on wet gravel/leaves accelerating smartly out of a rural intersection. I did have a slight wheelspin once starting off from the lights when I went driving and encountered some light slushy snow in the hills. Headed back to the flat pretty promptly after that...
I use Continental tyres, Conti 2 or something--basically one of the only tyres I can get in this country that fit my 15 inch lattices. It was either those, some Bridgestones with white writing on the sides, or some cheap Chinese junk.
BlownBrit
12-15-2015 06:35 PM
Frog
06-17-2013 06:46 PM
Jazz Cat
06-16-2013 01:03 PM
