Found TWR crank forgings
Old 10-30-2015, 05:13 PM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
Originally Posted by Jonathan-W
Blank forging to machine, believed to be spare forgings for the le mans cars. Can be machined to long stroke to make massive V12 engine! Part number EAC2757-84EXP. For quantity discount please contact us. Price each.
Crank Forging - Group C - TWR For Sale (1990) on Car And Classic UK [C100900]
Those cranks have been advertised for 5 years that I know of. Before anyone lays down cash maybe one of the UK forum members might go take a look to see what you are buying.
ronbros (10-30-2015)
Old 10-30-2015, 05:34 PM
ronbros's Avatar
Received 1,236 Likes on 943 Posts
wouldnt that be bitch, if they turn out to be just standard 5.3 forgings!
Old 10-30-2015, 05:59 PM
JagZilla's Avatar
In light of the astronomical expense of making something useful out of those forgings, how far can the 5.3 and 6.0 cranks be reliably stroked, and at what cost?
Old 10-30-2015, 06:04 PM
ronbros's Avatar
i think the OP has a stroked 5.3 shaft, donno!
Old 10-30-2015, 08:27 PM
xjr5006's Avatar
Group 44 offset ground the 5.3 crank for 75mm and bored the std liners for 92mm to get a 6L engine, A 6 L engine can be offset ground for 82mm to give 6.5L , both these drop the BE from 2.3 to 2.1 and then use chevy 6* rods.
JagZilla (10-30-2015)
Old 10-30-2015, 09:36 PM
JagZilla's Avatar
Thanks xjr5006.
Would that be Chevy 6 inch rods?
Old 10-31-2015, 05:10 AM
xjr5006's Avatar
Yes Chevy 6" with 2.1 BE There are chevy 6" with 2.0 BE but these are less common and therefore usually more expensive but would allow the 84mm out of a 6L crank.
Given the forgings only save you £200 at the machine shop as opposed to having a billet crank machined and you also have no risk with a machine shop supplied billet, no import taxes or carriage + insurance + agro of getting the crank to the machine shop, they are not worth the risk, The figures do not add up , which is why there are plenty sitting about. I dont know of anyone anywhere who has every got one machined up.
The following 2 users liked this post by xjr5006:
JagZilla (10-31-2015), Jonathan-W (12-17-2015)
  #28
Old 10-31-2015, 05:20 PM
warrjon's Avatar
I know someone who welded and offset ground the 5.3 crank for 78mm stroke. It was a lot of work as the cranks are nitride hardened.
Old 11-01-2015, 06:45 AM
ptjs1's Avatar
Received 3,033 Likes on 2,015 Posts
I know the people who are selling them. They are well-respected and technical advisors to the Jaguar Enthusiasts Club. I'll even see the guy at our AGM next week, so can ask him any questions that anyone would like to pose about the cranks.
Paul
Jonathan-W (11-02-2015)
  #30
Old 11-02-2015, 10:44 AM
Jonathan-W's Avatar
Paul
how much do they weight each...?
and should they be bead blasted to clean them up before starting to machine them...?
have they had anyone local buy and have one machined and if so who do they recommend to do this work?
I try to think of some more...
  #31
Old 11-02-2015, 03:28 PM
warrjon's Avatar
I inquired about these cranks 5 years ago and was quoted 400UK for shipping to Australia. I did a bit of research including shipping and machining. It was not worth the effort in Australia.
By the time I had them machined I could have had a billet crank made.
ronbros (11-02-2015)
  #32
Old 12-09-2015, 05:32 AM
xjsv12's Avatar
The following 4 users liked this post by xjsv12:
Jonathan-W (12-10-2015), ptjs1 (12-10-2015), ronbros (12-09-2015), superchargedtr6 (12-09-2015)
  #33
Old 12-10-2015, 12:35 PM
ptjs1's Avatar
Great to watch! I particularly like the programming that enables the grinding of the eccentric big-ends!
I guess this is why we can all rebuild an engine at home but none of us(?) have ever made a crankshaft at home!
Paul
The following 2 users liked this post by ptjs1:
Greg in France (12-12-2015), xjsv12 (12-11-2015)
  #34
Old 12-11-2015, 04:39 PM
Jonathan-W's Avatar
Paul
surely you mean for a road going autos ONLY.... there are some that cast there own push rods and wheels and stuff for their Scale steam engines
and a heisler steam locomotive does have a crank shaft and is a popular engine to show off ones prowess in the hobby...
and as home cad cam develops you will see more complex projects
the XJ13 for example... I expect that in the future some one will take the down loadable drawing of the car and put it into their computer and simply use it with a computer controlled plasma cutter and then just weld and pop rivet it together...
Sweet... and in time and smaller scale CNC machine for hobbyist that you could even make your own Kurbelwelle...
  #35
Old 12-12-2015, 02:57 AM
Greg in France's Avatar
Received 9,247 Likes on 5,431 Posts
Paul
Paul
Did you ever have a chance to ask your friend the vendor about machining these 84mm cranks?
Greg
  #36
Old 12-12-2015, 07:00 AM
ptjs1's Avatar
Greg,
I spoke to him only briefly when I saw him a few weeks ago. He said then that he only had one left. I'll drop him an email and ask about bead-blasting, machining etc.
Paul
Greg in France (12-15-2015)
FRGIII2014
11-18-2015 04:56 PM
01Silverstone
11-12-2015 01:15 PM
JessN16
10-30-2015 01:26 AM
evanlw85
10-29-2015 07:36 PM
lioncub
10-27-2015 10:27 AM
Quick Reply: Found TWR crank forgings
