Front Gaz shock
That will depend on the profile of the gaz bushes. There needs to be some means (usually a step down in diameter) of keeping the top bushes centred on the body mounting hole so the damper shaft cannot move and contact body.
ptjs1 (07-07-2023)
Greg in France (07-10-2023)
I wonder if GAZ has changed their settings. I have zero suspension at 13 clicks as the dampers are simply stiff as a steel bar. I’m at 4 clicks from softest with dampers purchased late 2019. I did by the way find the source of front right squeaks yesterday: it came from the damper, and going to fully soft and back to 4 clicks fixed it ( for now…)
The following 2 users liked this post by leo_denmark:
Greg in France (07-10-2023),
rgp (07-10-2023)
According to the dyno report delivered with them, they are GAZ GT6-2108, which according to Google should be the right type for XJ6, XJ12 and XJS. I can see they have 36 steps, so I agree it would be normal to be somewhere in the middle…
Greg in France (07-11-2023),
rgp (07-11-2023)
Greg in France (07-22-2023)
