Front license plate mounting?
Old 08-17-2013, 04:19 PM
Eaa's Avatar
Eaa
Eaa is offline
Default Front license plate mounting?
This doesn't seem like it should be that hard but ... 91 convertible, US model, the front bumper has a recessed area in the black plastic cover for the plate, along with two slots for bolts in the aluminum bumper itself. The only access to the back of the slots (to put nuts on the bolts) seems to be a hole, too small to put more than one finger through, not lined up with either bolt slot.
I guess it's probably possible to get a nut in using some really long tweezers or something but that seems like a huge hassle for something that should be simple.
Am I missing something here? How have you guys put that front plate on?
Old 08-17-2013, 05:17 PM
Vee's Avatar
Vee
Vee is online now
Received 1,562 Likes on 1,213 Posts
It's mandated in Virginia, however I have a facelift.
If you post a photo, I'm sure we could get you straightened out here.
If your state doesn't require a front plate, I would go without one.
Old 08-17-2013, 06:43 PM
Eaa's Avatar
Eaa
Eaa is offline
Hi Vee,
A front plate is required in Wisconsin as well, also the bumper doesn't look that great without something in that spot.
I may be able to get a photo, might be hard as it's the back side of the bumper, low and crowded.
I do have a plate on now, but fastened in a pretty half baked way - I'd like to do it better and more securely.
Thanks, Eric
Old 08-17-2013, 08:40 PM
Big_Walleye's Avatar
I have the same setup on my car. To attach the front plate I used an open end wrench and used some masking tape to hold a nut in the wrench. If you tape the nut at an angle in the wrench and insert it through the hole in the back of the bumper, you can then thread a bolt through the nut from the front. Do this on both sides and your plate is mounted. Kind of a pita but it worked for me.
bamforp
09-26-2021 08:04 AM
H20boy
07-23-2021 09:39 PM
PMKimpton
08-03-2019 08:22 PM
1964Daimler
09-09-2015 11:28 AM
SouthernGypsy
09-03-2015 10:54 AM
Quick Reply: Front license plate mounting?
