Front shock bushings, which one?
I need to replace my upper front shock bushes because my 91 still has the originals and I get the clinks and clanks over bumps.
In looking at this picture, what are the black bushes and the yellow ones? The blacks are simply "shock bushings", while the yellow are the "upper bushings"?
Thanks for the help
Thanks for the help
Those are Bilstien shocks in the pic. I put these in my car and with a 25mm front sway bar sharpened the car up dramatically.
The black go between the shock and the tower and the yellow under the nut. These are an upgrade to the OEM Jaguar units, but not as hard as rubber or Poly.
Do not use Poly anywhere in the front suspension (except the rack and maybe sway bar), you will regret it unless you race the car and NVH is of no concern.
ronbros (11-12-2015)
Poppyboy
11-04-2015 03:07 PM
