Front springs for 1994 4.0 XJS COUPE
Hi!
I've got sagging front spring and trying to find the correct replacement pair.
The difference between left and right sides is significant
(more than 1'').
The whole front feels tired, I've put packers on both sides
few months ago, it became better but not for long.
Plus I am the third owner and not quite sure if the springs
or dampers were changed at all.
So I decided to update both the shocks and the springs just
to be sure.
I've seen some topics with discussions of poor quality of
aftermarket springs for 6 cyl. cars.
I've found a few places with those springs available for
reasonable money (150GBP), but I'm not really sure that I
should buy them after all that I've read.
(Part No. JLM11310)
I've found threads about Eibach springs & GAZ shocks (XJ
Restorations), but this kit is really pricey (1500GBP).
I can't afford that now, although I'd like to go this way
(with adjustable rears later).
I can't find those springs for sale separately anywhere.
As far as I know, those Eibach springs were specially
designed based on Aston Martin DB7 springs.
I've found some AM springs from David Manners, but I'm still
not sure that they will fit my 6 cyl. car well (being
designed for 12 cyl. in the first place).
(Part No. RTC2751)
I'm sure there are plenty of XJS drivers who had similar
problems or questions - hope to hear about your
experience.
(more than 1'').
to be sure.
(Part No. JLM11310)
(Part No. RTC2751)
experience.
Just be careful that the springs you buy are for the 4.0 as well as the shocks. The PO of my 98 4.0 put spring and shocks good for both 12 cyl and 6 cyl on mine and I hate them.. After its smog inspected and I get over that pain I will be replacing my spring and shocks. She sits up like a 60's gasser.
Received 10,916 Likes
Greg in France (10-26-2016)
Yury,
I'm the guy who often mentions Eibach springs and Gaz shocks. I don't remember the Eibach springs being any more expensive than other quality alternatives. Try ringing Keith at XJ and get some prices. The springs were developed from the early AM DB7 springs but remember that was also a 6 cylinder car with the same front subframe as the XJS. I have a 4 litre and it's all fine on my car.
Good luck
Paul
Good luck
Paul
The V12 springs are the same as 6 cylinder models with the XK I6 NOT the alloy AJ6/AJ16! That is something very important to know.
The old XK engine weighs about the same as the V12... So if you fit V12 springs in an AJ6/AJ16 car, you'll be driving on hard springs far too high.
I bougt a set of new V12 springs and they have the exact same diameter as my old ones (if you remove the rust and add a layer of paint).
Hitch (12-02-2016)
We've changed only one spring temporarily for the test (after switching sides) and i'm still not satisfied with the result. The car sits higher on one side but it's definitely better than sagging. Now it's winter in Moscow and i don't drive my Jaguar, but will probably order Eibachs or aftermarket ones (fingers crossed). Will keep you posted.
Hmm, my V12 had a gap between tyre and wheel arch... I think as Yury wrote about 1-2 fingers (so long ago). The wheel should sit optically in the middle of the round wheel well...
If you look at the original listings for the Series III sedans (which used both the V12 and the 6 cylinder XK engine) you'll see several different springs for the 6 cylinder cars and several different springs for the V12 variants as well....none of the V12 springs being the same part numbers as any of the 6 cylinder numbers.
Same pretty much applies original XJS springs.
What I'm getting at is this: over the years a dozen or so different springs have been 'rationalized' into just two or three different part numbers.....with the RTC2751 being the most common. Presumably the spring is built to a spec that suits a wide variety of models fairly well but none of them perfectly well.
I get suspicious when I see a listing that covers a huge array of models, such as the RTC2751 being 'correct' for all Series II and II sedans regardless of engine and all XJS V12 from 1976 to 1996.
I think the (unstated) expectation is that'll we'll add/subtract the spacers to trim ride height when needed. That's am unpleasant notion.
..and remember that there's a difference between the body shape at the rear compared to the front. So the gap above the front tyre is quite different at the back. And of course, many owners of late cars with 16" wheels will be on 55 ratio tyres rather than 60 ratio which makes another difference. I would measure the distance from the subframes to the ground as detailed in the workshop manual.
Paul
Paul
What springs did you use? How were they listed?
I thought that might be the case. See post #11.
Yours is not a unique case. I've been hearing the same story for years. Incorrect ride height (too high in most cases) is common after spring replacement and I'm more convinced than ever that vendors are simply selling the wrong springs.
Anyone suffering from slightly sagging springs might well be better off by installing an additional spacer.....at minimal expense and a known result.....as opposed to spending money on new springs which, as often as not, are incorrect.
The factory nylon spacers are .125" thick and yield a .375" difference.
I hope some vendors see this thread and chime in.
I6 refers to the XK engine! Not the AJ! That is what many sites don't state...
