front sway bar bushings
I'm not sure which one you're talking about, but here's the link to the bushings on their website: v12s - Official Website
Just click on Polyurethane, then choose XJS. It lists all of them.
M90, the bushings you are referring to are called, subframe bushings. The part number is MHC2370AA. I do not know of any poly or urethane models. If there are maybe someone would care to post.
Poly bushings will squeak like hell unless you use the lube on them. Poly bushings wear out much faster then original style. They certainly are easier to install than original type. I certainly would not use poly on the lower wishbones. They are labor intensive to replace and if they start squeaking a bit of work to remove and lubricate. The rear radius arms might be a good place for poly, although you may end up with vibrations you never had.
M90power (05-04-2012)
Guy-Pierre Boucher
09-16-2015 05:55 PM
