Front wheel speed sensors
After soaking both sides in penetrating fluid, is there room to try and rotate them around? If they will rotate freely they should be freed up enough to start wiggling out. You may need to use some vice grips for a better hold or lots of light tapping with a nylon/rubber mallet to work them loose.
(I am assuming these are the earlier expensive ones with the round end)
This stuff boggles my mind. I had a hard time getting a sensor on a 2014 recently. Honestly, why does no one put anti-seize on these?
Reverend Sam
08-29-2021 10:47 AM
artstar
01-23-2013 09:09 PM
