front windscreen seal
I had an issue with water leaking and dripping on the stainless step. when I fitted it I used a copy, cheaper, seal and it puckered up on the top corners so this time I went for the twice the price one from sng about £93 inc del that they describe as jaguar, when I fitted the last one it seemed too large when fitting to the glass so I fitted it to the body and then slotted the glass in to the fitted seal, it wasn't to big then it seems that the glass is not a tight fit in the seal that's why it appears to large. also the join is at the top and I have read posters saying it should be at the bottom, who's right,
I have pro fitter coming on sunday, cash job, as I don't fancy doing it alone no
wadays
wadays
there is always a join, "should have gone to spec savers"
Someday your car is a facelift and has a bonded (glued in) screen, that gap is only a trim.
With the rubber gasket screen the join should go at the top. Also wI would use Polyurethane Window sealant both between the rubber and glass and rubber and metal. If done properly it will not leak again.
jagstuart
12-01-2017 01:28 AM
darren-talbot
12-24-2012 04:05 AM
Chaz17
05-06-2012 10:09 PM
