Fuel coming back up filler
My purge system has failed again somehow, I have again a heavy fuel smell in the trunk and cabin but now when I pop open the fuel cap I can see gas pumping from the overflow down into the neck like a waterfall of fuel. Thoughts? As a side note my fuel pressure regulator is dying, but I don't suspect they are related
This may or may not be a reason ?? There is a rain water drain opening in the gasoline fill sump. Is it clogged? If so, this might be creating a vacuum. Causing the gasoline to rise up into the fill tube. Point being there is not sufficient air to keep the gasoline settled. Had this issue on my 93 XJS.
Maine2003
10-04-2017 12:54 PM
Dr_killer_UK
10-10-2013 03:10 PM
jdoc84
10-15-2012 06:28 AM
