fuel failer
Guest
Posts: n/a
hi, I have a 1988/89 xjs 3.6, I am having trouble , the computer read out on the dash tell me there is a fuel failer,turn the key off then back on (this imfo is in the glovebox book) then it reads ff3 what does this means, the car is running fine,except when you are driving and back off it takes a while to respond (eg no engine braking till it idle down).
May have been a clutch or transmission problem. Not really sure. Try searching this site for answers --> www.2carpros.com/
jaguar xj6 xj40 radiator
FF3 is the temp sensor. You are probably running very lean, but that's ok. You can buy one here:
http://www.motorcarsltd.com/item.wws?sku=IN100004
WTB[SouthEast]: 2000 XJR door seal
moff1959
09-26-2015 05:35 PM
XKE73EIconverter
09-26-2015 10:21 AM
